It is currently Thu May 23, 2024 1:43 pm
PostPosted: Wed Apr 09, 2014 9:02 pm
Hi guys i posted on here awhile ago about my ca 16 engine in my race car fluffing/missfire/studdering as of yet the issue hasnt been fixed since then i have checked the earth straps and found all ok the coil pack is fine i have changed fuel tank to a fuel cell thinking that there might have been some crap in the old tank when i last ran it which was last sunday the car had a few fluffing but then seemed to clear and the car ran without any problem untill the last couple of runs the studdering had returned to a point where the car felt like it had no power then it would clear then it would go into studdering again then clear then back to studdering i went over a bump on the track and all of a sudden the car came to life and it reved out to 7,500 rpm with out any trouble and the it was like a rocket but then the studdering was back thats if you call it that but i noticed the tacho was erratically going from 2,000 rpm to 5,000 rpm anyone have any ideas what this could be its starting to do my head in cheers
PostPosted: Thu Apr 10, 2014 7:12 am
I was thinking fuel pump right up until you mentioned the tacho - it's got to be whatever is firing the coil pack, either the ECU or separate ignition module. As a test you could even disconnect the tacho wire to make sure that's not interfering, depends if you take the tacho signal off the ECU or somewhere near the coils.
Users browsing this forum: Google [Bot] and 3 guests
