It is currently Tue Jun 04, 2024 9:26 pm
PostPosted: Mon Jan 20, 2014 2:35 pm
Hi All,
I work for Suspension Stuff and am going to make a set of rear Mono Tube shocks for my 1600. Without removing my shocks first I was wondering if anyone has the open and closed lengths of the shocks? may take a while to get the valving right and I have 3 different Piston designs to play with but hopefully should be able to do something better than whats on the market currently thats for sure. This is for a lowered 1600 with high HP (200+) I am hoping to reduce body roll improve ride quality and give maximum traction. As its on a lowered Datsun should I reduce the overall height of the shock or leave it as it is?
Cheers Steve.
Yellow 1600 with CA18DET and lots of other fun stuff.
PostPosted: Tue Jan 21, 2014 1:14 am
Call a spare parts place and ask them to look it up in the back of their Monroe catalog. From memory 1600 & 180B are the same. They may not be in the current catalog but a good place will still have it in an old one.
Stock open length should be fine- there's no need to reduce the suspension droop and unless you're changing the bump stops you won't need shorter shocker bodies.
Cheers!
PostPosted: Tue Jan 21, 2014 12:10 pm
Sweet as, found an old Monroe Catalog here so have the info now.
Open: 599
Closed: 348
Now to get building and testing.
Cheers Steve.
PostPosted: Tue Jan 21, 2014 7:04 pm
You can also call the Monroe technical help line and get this info if you dont have access to a catalogue...
