Wheels for a 1600 offset needed http://ozdat.com.au/forum/viewtopic.php?t=30780 |
Author: | Ajdat16 [ Thu Feb 28, 2013 8:32 pm ] |
Post subject: | Wheels for a 1600 offset needed |
I'm looking for wheels for my 1600 it has stanza struts in it and I want to run 15 inch wheels or maybe 16's and I assume 7 inch wide is as far as I can go but not sure on what offset I will need |
Author: | nick [ Thu Feb 28, 2013 10:00 pm ] |
Post subject: | Re: Wheels for a 1600 offset needed |
Not exactly sure about stanza struts but id start trial fitting something around the +10 to +15mm mark with a 15x7... Heres some reading for you: http://www.ozdat.com/forum/viewtopic.ph ... eel+offset http://www.ozdat.com/forum/viewtopic.ph ... eel+offset http://www.ozdat.com/forum/viewtopic.ph ... 5x7#p69934 http://www.ozdat.com/forum/viewtopic.ph ... light=15x7 |
Author: | Ajdat16 [ Fri Mar 01, 2013 5:19 am ] |
Thanks heaps nick I should be able to work it out with this much information |
Author: | OLDATO [ Fri Mar 01, 2013 7:58 pm ] |
The wider the wheels on the front, the heavier and more sh*t it feels to drive! |
