are there any auto gurus out the that can tell me how much play is acceptable on the output shaft of a 3n71b
i have two boxes here (one is currently in the car) and both have a similar amount of play, but one was good until i busted the trans oil pump bearing and the one that is in the car now is of an unknown reliability
i replaced the rear seal tonight and it is leaking more fluid then before i replaced it, also appears to have been chewed out a little on the inside from the tailshaft (rear seal was replaced due to fluid loss, but am now suspecting the rear bush on the shaft)
any help is appreciated
