Wiring Pass Relay in a 1600 http://ozdat.com.au/forum/viewtopic.php?t=30192 |
Author: | Nissanman [ Sat Dec 08, 2012 12:00 pm ] |
Post subject: | Re: Wiring Pass Relay in a 1600 |
A conventional relay will be fine on at least two counts: - It will be standard pin numbering and won't cost the earth like an OEM Nissan relay Just to be sure to be sure, here is the equivalent in Bosch/Hella/Narva speak: - Attachment: 3078.gif [ 3.57 KiB | Viewed 1347 times ] |
Author: | rallydat510 [ Tue Apr 02, 2013 1:46 pm ] |
Turns out I didn't need to wire in the pass relay as it is part of the Pulsar combo switches. Does anyone have a wiring diagram for converting 1600 lights circuit from switch earthing to light/relay earthing? Thanks Richard |
