It is currently Fri May 24, 2024 12:14 am
PostPosted: Sun Jan 22, 2012 8:56 pm
Hi Guys,
Thought i might post some pics and info of my bluey. here goes.
Started out as a 85' Series 3 TRX completly standard 90k on the clock, purchased from vic and then we drove it back to Adelaide, for the big transformation.
Traditionally its ca18 turn key..But i decieded to go the sr route.
Mods are as follows
S13 coilovers all round, custom laser cut camber plate.
Welded diff, new bushes, bearings, rebuilt rear calipers and slotted and drill discs.
Custom 3' tailshaft
R31 wagon fuel tank with gtr intank pump
s15 SR20det 6 speed
s13 engine crossmember including power steering
cazman industries adjustable castor rods
4 pot calipers
s13 swaybar
cooler
ally rad
nistune
apexi pod filter
32gtr wheels
fullriver drycell
plenty more things i have forgotten, car made 165rwkw with a suspected clogged exhaust.. car was built for datnats 11' which it made it too, drove there and back no dramas....
Currently in the plans are injectors/z32/e85 and a topmount turb.... soon to come.. heres some pics of the build..
Bay degreased ready for a quick cut n polish
S13 crossmember compared to the S3 bluebird crossmember, not alot of difference at all.
Fitting the s13 crossmember rear bolt holes are 4mm out and the front ones will need to be re-drilled and crush tube put in
By shannonashman at 2011-09-28
Shannon
S15 SR20DET 85 910 TRX currently making 165kw
PostPosted: Sun Jan 22, 2012 9:29 pm
Very nice conversion you have. Job well done!!!
Stu.
PostPosted: Sun Jan 22, 2012 9:30 pm
NICE looks good
YOU JUST GOT TO LOVE JDM AND BMX
current rig's:
1970 datsun 1600 p510: 73 SPEC WITH SR SHED
prev rides:
1970 datsun 1600 wp510 project SOLD
1969 datsun 1600: SIMS metal
1984 KE70 corolla:defected/crushed
1985 KE70 corolla:SOLD
1982 KE70 4AGE drift pig SOLD
1978 120Y wagon SOLD
PostPosted: Mon Jan 23, 2012 9:08 am
Nice :thumbsup: I remember having a good look at datnats tidy conversion
PostPosted: Wed Feb 01, 2012 5:48 pm
Thanks for the kind words guys, should make abit more power in the next few mnths, which will be good..
Bring on datnats '13 ha
Shannon
PostPosted: Wed Feb 01, 2012 7:11 pm
Freaken awesome. Nice work fella! Looks like good quality workmanship too which is great to see.
PostPosted: Sat Nov 24, 2012 10:24 am
Top job. Got a few questions for you, are they s13 lca's? What are the caster rods off? I'm after some caster rods the same as yours. Also, what radiator hoses have you used? Cheers.
PostPosted: Sat Nov 24, 2012 1:37 pm
Cheers mate, lca's are s13. Castor rods are r31 adjustable rods supplied by Cazman industries, google him or I can give you details. Radiator hoses, top is supplied by datsport to be used with there cnc'd coolant outlet fitting. The bottom hose I have a temp gauge in so the hose is cut in half, also supplied by datsport.
Hope this helps, ring datsport and speak to Cam.
Shannon
PostPosted: Sat Nov 24, 2012 1:44 pm
great job mate, who did the I/c piping?
-1969 1600 SR20
PostPosted: Sat Nov 24, 2012 6:44 pm
I cut and tacked together then had Cam at Datsport weld it up for me.
Shannon
