OZDAT
http://ozdat.com.au/forum/
120y race car
http://ozdat.com.au/forum/viewtopic.php?t=30106
Page 1 of 5
Author:  Danny747 [ Tue Nov 20, 2012 8:22 pm ]
Post subject:  120y race car
Hi fellow 120y fans i thought i would post some pictures of my 75 model that will be used for sprints and hopefully a winton six hour one day.
S15 sr20de made 92 kw atw standard motor
200b front struts
XYZ shockers rear
borg warner rear end with mini spool
S15/PBR Brakes.
Performance 15/7 rims
Cheers, Danny
Author:  trb012 [ Wed Nov 21, 2012 9:35 am ]
Post subject:  Re: 120y race car
Looks cool mate :thumbsup: What times have you run around winton? Im heading there in my y next weekend a mates bringing his na sr powered sunny racecar as well :D
Author:  Danny747 [ Wed Nov 21, 2012 3:57 pm ]
I haven't had her out as yet still sorting out minor issue with the front end. I am hoping to get a friday practice in before xmas.
I have been following you build, love the z18 option nearly went down that path myself. I once had a really clean stanza sss with a Z18 with motec head work and big cooler. Had to sell the car to buy my house.
Have you ever weighed you 120y? would be interested to know the weight with you mods.
Your mates name isn't Joe or barry by any chance is it?
Cheers, Danny
Author:  trb012 [ Thu Nov 22, 2012 12:14 pm ]
No Ive never weighed it something Ive wanted to do for along time but never got around to it will one day but. My mate with the sunny's name is Chris his car is pretty fresh its only seen the track a few times so far. look forward to your progress :D
Author:  180BSSSt [ Mon Dec 03, 2012 6:01 pm ]
Hey Stu, I think there's a public weighbridge on Colchester Road.
Author:  trb012 [ Fri Aug 30, 2013 10:46 pm ]
Nice to meet you today mate hope your day went better than mine :lol:
Stu
Author:  Danny747 [ Thu Sep 19, 2013 9:10 pm ]
Hi Stu, It was great to meet you and your friend with the 1200. I hope it wasn't anything serious with your car.
Its a shame you left so early i wanted discuss some handling issues with you.
I had a great day thanks, not bad for the first time out in over 10 years.
I had some trouble with the brakes, the pedal was way too hard running no booster and a 15/16 master.
I have since gone down to a 13/16 from a silvia so should be able to lock the brakes now.
I was very rusty and started around 1.58 at the end of the day i did a 1.47.
I am going up with Friday 27th hopefully with another 120y sr20det which does mid 30s. Apparently the car used to belong to Adam Macrow.
If your free it would be great to catch up again and get 3 of us on the track.
I weighed my car before the meet with 1/4 tank of fuel and it was 935 kg.
Cheers, Danny
Author:  trb012 [ Fri Sep 20, 2013 9:48 am ]
No nothing too serious just sprang a coolant leak that I was unable to fix trackside. 1.47 is a quick time so far mate best ive done is a 1.47 too when the car was on gas so hoping for low 1.40's on e85 and more track time. Would love to come back on the 27th but I think my racing will be over for this year just got a lot coming up over the next few months.
Author:  Danny747 [ Sat Sep 21, 2013 4:24 pm ]
I understand about lack of time I have 2 kids and not much time for cars these days.
I will keep you posted on my lap times if I get some improvement.
Are you a car club member?
Author:  trb012 [ Sat Sep 21, 2013 9:37 pm ]
Yeah ive only got one little one at the moment and that's hard enough to get spare time I haven't touched the car since winton :lol: . Will get it fixed soon but im looking into doing a cage soon as well for a bit more confidence and safety :D Im a member of piarc you?
Author:  Danny747 [ Sat Sep 21, 2013 10:14 pm ]
I was in piarc but i think i will sign up to benalla
Auto club soon. Winton is good for car setup
and safety till i get used to the car.
I can recommend brown Davis for a cage
they are a bit pricy but they do a great job.
My plan is to do a six hour one day, would be
good to form a 120y team.
Cheers, Danny
Author:  trb012 [ Sun Sep 22, 2013 9:50 pm ]
Yeah I've spoken to brown davis just weighing up my options. 6 hour sounds cool just need to get my car reliable :lol:
Author:  Danny747 [ Sat Sep 28, 2013 9:02 pm ]
Hi, Stu went to Winton Friday and did a
1.44.5 and had a great time. I still have
issues with the brakes which we think is
brake pad knock off causing the pedal height
to change after cornering hard.
I too have a borg warner with r32 callipers, I think one is slightly
twisted on the mounting bracket. I had to
Pump the pedal on the straights which was
a little dodgy.
I was hitting the rev limiter on several corners may have
to look at changing diff ratio.
I am also going to remove the
gearbox as I have an oil leak around the shifter.
Cheers Danny
Author:  trb012 [ Sun Sep 29, 2013 8:18 pm ]
Nice one mate im sure you will get the brake issue sorted soon. I pulled my manifolds off over then weekend so should be track ready again over the next week or so :D
Author:  Danny747 [ Sun Sep 29, 2013 10:50 pm ]
Thats good its going back together so soon rusty studs in Z18 heads are a bugger to get out.
Can you tell me Stu is your diff assembly out of an r31 skyline or something else?. The reason i ask is that you have R31 rear callipers and Im interested to know if R31 brake calliper mounting brackets will bolt onto older style borg warner diffs like mine.
I have seen them on ebay at times and would like to piss off the welded on brackets that are causing me braking issues.
Being a Z18 i am sure the torque curve is completely different to my car but i am curious as to what sort of revs you are pulling on the two corners after the sweeper and on the two corners on the new section of the track?
Cheers, Danny
Page 1 of 5 All times are UTC+11:00
https://www.phpbb.com/
