bleeding master cylinder http://ozdat.com.au/forum/viewtopic.php?t=29893 |
Author: | MangaNOID [ Wed Oct 17, 2012 4:15 pm ] |
Post subject: | bleeding master cylinder |
I think I have 'bench' bled my master Cyl successfully but there are two bleed nipples? on the side of the MC. should I bleed from these also? I have only bled from the proper fluid line exits underneath. Attachment:
Author: | Nissanman [ Wed Oct 17, 2012 4:33 pm ] |
Post subject: | Re: bleeding master cylinder |
In a word, yes. |
Author: | MangaNOID [ Wed Oct 17, 2012 4:46 pm ] |
oh it looks like I bled from completely the wrong place now I'll have fluid dripping al over the place when I disconnect the bleed lines. thanks for that! |
Author: | MangaNOID [ Thu Oct 18, 2012 2:12 am ] |
ok the bleeding from the bleed nipples went much better than were I had the bleed lines hooked up to. it all went very smoothly which is almost a worry. just wont find out until I drive it again in a couple weeks. thanks for your help Nissanman. |
Author: | Woznaldo [ Sun Feb 26, 2017 12:28 pm ] |
Can I do the bench bleed of the MC on the car? I.e. Hook up to the bleed lines between the MC bleed nipples back to their respective reservoirs? |
Author: | Woznaldo [ Sun Mar 05, 2017 10:14 am ] |
In a word, yes. http://ozdat.com/forum/viewtopic.php?f= ... 67#p266367 |
