Hi All,
I finally got around to removing the paint from one of the quarters on my Datsun 1600 tonight and I’ve found a few holes where the rust bubbles were. Kind of expected it but I was hoping to find some pristine steel under the paint! Aren’t we all!
Anyway I’m hoping to get some input from people who’ve done their quarters before… Should I patch the panel with individual sections of sheet metal or get a replacement lower quarter panel section? Check out the pictures and let me know what you think… any inputs will be greatly appreciated! There’s only one hole on the inner panel visible from outside, and quite a few in the outer panel at the boot floor level, the bottom and around the back corner section.
So far I see the benefits of each as follows:
Pros for using a proprietary replacement lower quarter replacement panel:
- Knowing it’s done properly and ensuring I get all the rust and areas with section loss without the chance of missing some
- Access to inner panel to properly inspect, clean, carry out any repairs to inners and properly protect / coat inside
- Assume it will be a better outcome and look better
Pros for replacing individual sections / areas with sheet metal:
- Probably easier(?), except for the corner section which is likely to be pretty hard to shape
- Cheaper (although don’t mind paying some extra for a better result)
I haven’t ever replaced a lower quarter before so I’m not super confident and a little reluctant. That being said I’ve replaced and welded in a number of sections already and seam welded the shell using the mig so willing to give it a go. How hard can it be?! Hopefully I don’t regret saying that!
If I end up grabbing a lower quarter replacement panel I’m assuming from the posts I’ve read that I should go the Nissco as it appears to have the best fit and will require the least effort to fit. It’s just a fair bit more expensive! Any cheaper alternatives people recommend? I’ve read a bunch of bad reports for other brands
Also, should I be using POR15 on the inner before I weld in the new patches / repair section or some other product? Plan on fish oiling / waxing it all after repaired.
Thanks heaps for any input.
Chris
