Thanks mate, yeah im going to do everything properly on this build I don't know why people would want to cut corners. Do it properly the first time. The poor man always pays twice ( not saying im rich far from it that's why my project is taking a while haha). I have looked at the strengthening section a few times. Im not going to seam weld but I am installing the front a pillar section and the rear bracing between the rear strut towers, just waiting till I buy a after market fuel tank and get it mounted at the same time when the sills get replaced etc. ill be getting the wheel well removed too and will be getting a recess for the fuel tank to sit in.
So I have done a few more things.
- Fitted the datsport steering box brace
- Drilled the hole for the plms loom
- Drilled the holes for the datsport sr20 fitting kit crush tubes
- Drilled holes In the forward wheel wells and fitted bulk head fittings for the brake lines to go through
- Fitted the datsport brake booster in preparation for making brake lines
- I have been mucking around with the wilwood brake bias valve. I like where its mounted but I am trying to work out how best to move it of the inner guard for easier access to adjust it
- Painted the SSS dash surround ( still needs a touch up where it meets the chrome. ill need fine line tape)
- Bent up the stainless 1/2" fuel lines. The first one I made a bend in the wrong direction
the second one turned out great
- Made mock up cupboard catch can and window washer bottle. ( if anyone has any other ideas for this please let me know
69 SSS dash surround painted
steering box brace, bias valve, crush tube holes, brake booster, washer bottle mock up and bulkhead fitting
plms loom and catch can mock up
Im also looking into a brake booster brace. I have found one in the USA but its for left hand drive and no hope of them making a righthand drive
does anybody have any leads? failing that I may have to make one
https://technotoytuning.com/nissan/510/ ... datsun-510
Richard
