It is currently Sun Apr 28, 2024 10:17 am
Post new topic  Reply to topic  [ 58 posts ]  Go to page 1 2 3 4 »
 Post subject: my 66 411 wagon
PostPosted: Wed Nov 09, 2011 9:28 pm
Hey guys n gals,
Thought i might put a few pics up, and introduce you to my little car!!
shes a 66 411 wagon, the body has previously been resprayed, lights have been altered to new LED's, interior re-trimmed, thats about it.
my plans are to get the original 1300 motor up to scratch if possible, if its no good, will probably be throwing an L20 in it, which will probably mean getting rid of the column shift :( , will be modifying the interior a bit to suit me, and fixing soe semi-dodgey work. my plans are to eventally put her on air bags, and venetian blinds hahaha.
i have no idea how to upload photos but im going to try! help please!! haha
thanks
shane
[img]flhs1[/img]
NEED MORE GRUNT - ROOT A PIG
 Post subject: Re: my 66 411 wagon
PostPosted: Tue Nov 15, 2011 1:15 pm
heres a few pics of my 411 wags.. will keep you posted on how my motor goes when i get home!! hopefully all is good with the original J13 so can keep it original - besides the lights obviously!!!
PostPosted: Tue Nov 15, 2011 2:05 pm
nice looking ride mate, theres a 1500 j15 engine at pickapart in kylsith
in very good condition if you can get it.
Also some1 here was selling a complte j15 with gearbox for like 100 bucks
in perfect order, I think nsw, where are you put your location in will help others help you.
PostPosted: Tue Nov 15, 2011 2:59 pm
hey mate, yeah a j15 would be nice! do you know if the 15 would bolt up to a 13's column tranny? i wouldnt mind sticking to the colum shift for a bit of old schoolness!! could be keen to get a j15, do a little bit of work to it, then throw her in.
PostPosted: Tue Nov 15, 2011 3:06 pm
Cool looking car. I've got a J15 in bits and a complete J16. I think there is a gearbox there as well if the J13 has a different bolt pattern.
Chuck me a message and we can talk.
Trev
There's something about twin webers at full noise.
PostPosted: Tue Nov 15, 2011 3:25 pm
There you go a j16 even better with column shift all perfect.
PostPosted: Tue Nov 15, 2011 6:57 pm
cheers for that mate. i read today that the j13, j15 and j16's all have the same bellhousing bolt pattern. so if this is true, a J16 should bolt straight up to it. now to try to find some good parts for a j16!!
has anyone done much on 410/411's before? i want to get rid of the drums and run discs.. need to know where to start looking!
PostPosted: Tue Nov 15, 2011 7:14 pm
wonder if you can run R31 skyline disc brakes in the rear?
1979 Datsun Stanza Coupe
1979 Datsun Stanza GX
1982 Datsun Stanza GX
1966 Nissan Cedric Custom Six
1972 Volkswagen Beetle
EziAutoParts
PostPosted: Tue Nov 15, 2011 8:09 pm
hmmmmm.. no idea! what about fronts???
PostPosted: Tue Nov 15, 2011 8:15 pm
struts from another datsun might fit?
EziAutoParts
PostPosted: Tue Nov 15, 2011 8:32 pm
yeah, i'd like to have discs on the front minimum. discs all round would be the bees! i can feel some research coming on!!
PostPosted: Tue Nov 15, 2011 8:48 pm
Hmmm, thinking out loud here.
410's (and I would assume 411's as well, although I could be wrong as I don't have a 411 parts manual) run the exact same front drum brakes as the SP310 fairlady. Same part numbers, the lot. I have a full set of 410 wheel cylinders (all 6 of them :shock: ) to use on my SP310 fairlady and they are identical to the existing ones on the fairlady.
The SP311 / SR311 fairlady's run a disc front end using Dunlop calipers, and can be upgraded easily with minor mods using Volvo 4 spot calipers (google will fill in the details). You can also buy a kit to put 300ZX 4 pot calipers on a 311 fairlady (google "Spriso Motorsports").
So, it comes down to whether the 310 and 311 fairlady front ends are same / similar enough that brake upgrades for the 311 fairlady will work on the slightly earlier 310 fairlady. And there, I can't help (well, I could, but I'd have to dismantle my 310 and 311 fairlady's and see if the brakes swap over). Perhaps try some of the fairlady forums (311s.org, for example) and see if anyone can confirm ? Or else, find an upgrade for a SP310 fairlady and it should work on a 410 / 411.
Another option (but I would imagine not easy to find) is the front disc setup off a 411 SSS (although perhaps they are just fairlady brakes, the 411 SSS did use the fairlady engine / gearbox).
For rears, pretty sure they use the same drum as your run-of-the-mill Datsun 1600 (again, fairlady's do, and 410 / 411's use similar brakes to a fairlady) so an R31 upgrade should be do-able, although you will probably have to work out how to modify the caliper mounting bracket yourself.
I was lucky to find a set of cheap NOS 410 brake wheel cylinders to use on my fairlady - to buy NOS SP310 fairlady ones you're looking at upwards of $500 just for the cylinders :shock: , so a brake upgrade will save you money as well as make it stop better.
All just theories, but maybe a reasonable place to start ?
PostPosted: Tue Nov 15, 2011 8:52 pm
I can 100% guarantee they won't.
411's don't have struts :wink:
PostPosted: Tue Nov 15, 2011 9:00 pm
yeah, thats some awesome info! cheers mate.
i've said it before, but all the info that i can get is a massive help, as this is my first datto project, i've only dealt with holden/chevs before!
cant wait to see if all this actually works!! i hope so! i get home in a week, so will have a few weeks to tinker with her.
411's dont have struts?? i havent even had a look yet! actually, yeah there is no tops in the engine bay now i think of it!! hmmm...
cheers again
PostPosted: Tue Nov 15, 2011 9:02 pm
awwwkwarrddd
EziAutoParts
Users browsing this forum: No registered users and 14 guests
