It is currently Sun Apr 28, 2024 10:22 pm
PostPosted: Tue Nov 08, 2011 11:22 pm
Hey all just wondering if the combination swith, barrel and covers fit/work on a 1600 steering colum? Cheers
-1969 1600 SR20
PostPosted: Wed Nov 09, 2011 1:12 am
I grafted 200B stalk controls into my old 1600. Fairly awkward as the 1600 column was fatter than the 200B one and I had to enlarge the bore of the combo switch to suit.
If nobody else has done this, first stop is a wrecker to measure S13 column diameter, shroud length, plus check the steering lock and barrel setup to see if it can be adapted to the 1600 (which doesn't have one). Or maybe you could make a bracket to place your 1600 barrel in the right spot for the S13 shroud. Will the your wiper motor match the S13 controls?
This could be pretty time consuming to wire up, but would be great to use. Good luck!
