It is currently Mon Apr 29, 2024 3:25 am
Post new topic  Reply to topic  [ 135 posts ]  Go to page « 14 5 6 7 8 9 »
PostPosted: Sat Aug 27, 2011 1:40 pm
Are they grommets or just really small cable glands. Perfect for running your battery cable through the firewall at any rate!
PostPosted: Sun Aug 28, 2011 11:35 am
Cable glands are great for passing wires or hoses through panels. I used them quite a bit on my car build. Jaycar sell them pretty cheap
http://www.jaycar.com.au/productResults ... SUBMIT.y=0
2005 Mercedes AMG E55 350 kW
PostPosted: Sun Sep 11, 2011 11:19 pm
Been a while since an update... been super flat out :? but have made some progress on a few things,
Mounted my fia kill switch,
Fitted my air flaps to the inside of the car, Made a blanking plate for the heater box entry. And covered behind the dash with our insulation.
Fabricated the dump pipe of all dump pipe's :lol: of course as you know nothings simple on this car, Baz convinced me to give an old proven theory a shot. This theory is based on the exhaust flow from the rear housing. According to a well published book (which has many proven facts from drag cars through to f1's) is that the spiraling air from the rear exhaust wheel will keep air speed up as it enters the dump pipe, Which can work against the rear exhaust wheel in rapid rpm changes. So to cut the story short, if theory proves us right I should get some better response out if the hair dryer. Anyway we sat down and done a mock up to see if we could get it to work and came up with this. A tapered (from the inside of the flange) 2.75in to 4in cone into a 4in mandrel bend and back to 3in again... after around 6 hours this is where I got.
I firstly needed the flange, which I was happy to make. But after seeing a couple of mates they decided to short cut me by drawing up the flange from the gasket (within 3mins :shock: ) and then chucking a piece of 10mm stainless in there CNC Mill 8) not the normal practice, usually laser cutting is adequate but they know how impatient I get.
After some die-grinding, cutting and swearing we had it tacked.
And now the welded product with the test fit.
PostPosted: Mon Sep 12, 2011 3:19 am
Is that your high octane fuel in the black can :giggle:
Just an idea for a jump start, run two separate leads from battery out to an inconspicuous point, then have a receptacle on the end. Google caterpillar jump start receptacle. just make sure you have a set of leads with a receptacle on one end.
I could possibly sneak you out two receptacles from work if you wanna do that :D
Keen to see the camping dryer conversion, I'm a bit over trying to win a sss heater from Tokyo 2u.
Dan.
PostPosted: Sun Sep 18, 2011 10:00 pm
Dan.
haha yep all the special juice! cheers man, I reckon I should be ok though... because i dont have poppers or anything stupid like that i'll just use a jump pack on the inside if i ever need too!
Gave the rocker cover a detail, Drilled and tapped the breather holes for speedflow/aeroflow fittings, was going to do a catchcan but caved and kept with the oem sealed system... If i run into any breathing problems i'll look at that down the track! Used stainless washers and dome nuts around the rocker cover.
Made my new front wiring harness as per our spec... except I made an alloy bracket and machined up some bosses because I could....!
PostPosted: Sun Sep 18, 2011 10:41 pm
your flippin bonkers camo
PostPosted: Sun Sep 18, 2011 11:45 pm
Gotta give credit where it's due. This is how I would build one from scratch, top work.
PostPosted: Mon Sep 19, 2011 8:01 am
Love the engine bay, i only hope mine comes out just as good.
Top stuff.
PostPosted: Thu Sep 22, 2011 3:04 pm
this is one awesome looking build everything is so professional very impressive :thumbsup:
good food good life great car "1600"
PostPosted: Sat Sep 24, 2011 12:08 am
Thanks for the comments guy's :D
got a bit further with my radio facia, installed my new ignition switch and starter button... more effort to start the car lol but its pretty cool!
with the old ignition switch
Oh and did I mention i kicked him in the guts too!! :woohoo:
http://s19.photobucket.com/albums/b194/ ... bb8917.mp4
PostPosted: Sat Sep 24, 2011 12:22 am
that sure is different! Looks pretty awesome though!!
I love how this project is heading, very unique etc :)
1979 Datsun Stanza Coupe
1979 Datsun Stanza GX
1982 Datsun Stanza GX
1966 Nissan Cedric Custom Six
1972 Volkswagen Beetle
EziAutoParts
PostPosted: Sat Sep 24, 2011 1:05 am
That's what I was planning for mine and how I did my old 16. However both times i'm planning on using the ignition barrel on the column as the switch, then the separate start switch elsewhere. Looks good though mate, bet it feels good that its started finally!
PostPosted: Sat Sep 24, 2011 7:51 am
Fantastic Cam :)
PostPosted: Mon Sep 26, 2011 10:01 am
Sounds lumpy!!
PostPosted: Tue Sep 27, 2011 10:16 pm
SR20Datsun wrote:
Sounds lumpy!!
Yeah kinda scary Nick!!! :roll:
hailest wrote:
Fantastic Cam :)
thanks trent!
Thought i'd do another few updates of my wiring, Using a sunny combi switch...
My 1970's Z wheel that was passed down from my uncle who was rallying my grandpa's 1600, i'll be running between that and a Nardi....
Wiring behind the dash facia
Fuse box installed on the pedal box
Wires tidied up..
