I was looking at using a newer fusible link (the plastic 2 pin/leg type) but couldn't find a holder, never thought of the Maxi Fuse, and I see I can get an inline holder for it too.
Problem solved! Cheers guys.
Don't forget, the fuse [rating] is there to protect the wiring, not vice versa
I get that it's there to protect the wiring, but haven't ever really thought about them in the past. It needs to handle the current draw of the car right?
So say headlights on, high beams on, radio on, fuel pump whirring away, brake lights on and I hit the horn! All with the interior light on indicating to turn left.
But if there's a spike she blows... i.e. when people jump start cars wrong. So what is too big a fusible link? And how do I work out what is too small?
I am running standard almost everything, with halogen headlights (55w/60w) + (100w) through 30A fused relays, and a stereo (no amps, no subs) that has it's own 15A fuse built in. Fuel pump will also be through a 30A fused relay.
