Saturday 13th Feb
Work continued through the week, just no time for updates.
1. Fuel has arrived and ready to be decantered into 20L drums.
2. Brake Pads have arrived and have beem fitted. Also checked all pistons in the calipers - everything ok.
3. Re-set ride height in the rear of the car. Now it's even
4. Collected restrictor from workshop and refitted along with the airbox.
5. Re-fitted old air temp sensor - waiting for new one to arrive early in the week. Need to start the car though, so had to refit old one for now. (mongrel of a job as the starter motor has to come out to get the sensor out)
6. Re-fit exhaust System - rear section. Exhaust has to come off to get enough droop in the rear end to change springs and adjust ride height.
7. Cleaned wheels - inside & out.
8. Washed & polished car - Outside, inside, engine bay & boot.
9. New door trims - thanks to my lovely partner Nadine! (You rock babe)
Car is now ready for tomorrow's Festival of Motorsport Show at Kwinana, but still some work to be done next week to get ready for next weekends race meeting (and practise on Friday)
Things still to do:
1. Swap air temp sensor with new one
2. Dyno (hopefully Tuesday) for re-tune with restrictor
3. New tyres being fitted on Wednesday (rear only)
4. Wheel alignment Thursday morning.
5. Flush Brake fluid
6. Bleed brakes
7. Decanter Race fuel.
Going to be a busy week!
www.full-throttle.com.au
www.boostcooler.com.au
When the Flag drops........... the Bullshit stops
Go hard or go home!
