It is currently Wed May 22, 2024 12:06 pm
 Post subject: Handbrake swap...?
PostPosted: Thu Mar 11, 2004 7:45 pm
Hello peoples,
Whats the go with tunnel mounted handrake conversions for 1600's, im after a setup which will be able to mount up to either standard rear drums for starters, and whats a good setup if i get around to swapping to R31 rear disks...
What has anyone used?
(Ive heard of 120y, stanza or 240z?)
If i find the parts on a wreck what will i need to be able to hook it up?
(I dunno what cables to use and if i need any brackets or attachments)
And last of all any installation advice?
(Please anything...)
PostPosted: Thu Mar 11, 2004 8:08 pm
I have fitted a Stanza centre console handbrake lever to a 1600.
The cable exits the cabin at the junction of the floor pan, trans. tunnel and the front of the rear seat platform.
I made a pivot box and lever to mount onto the chassis rail and the handbrake cable pulls on this lever.
The rear cables connect to the end of this lever with the standard balance bar arrangement.
From memory, it would work OK with the rear drums but I already had the R31 rear discs which required a custom made rear cable anyway.
The standard 1600 rear h/brake pivot and lever is of no use where it is welded to the body.
The custom pivot box was the result of 2 prototypes which were too weak.
The current one has survived for 5 years now :wink:
There is a lot of tension put on that linkage when you yank on the h/brake :shock:
