Im running a 71b with a holinger gearset
I dont have any photos of the broken syncro or the baffle as it was completed in Vic with les.
I have a few syncros in the shed and i will post a few photos of the spot i believe it broke.
I think i saw 120-130 degrees in the gearbox, but not sure. Will have to have a look at the motec logs
I definitely remember seeing 150 degrees in the diff, although this was the first track day in summer after the diff was rebuilt. I would expect the highest temps when the diff plates were new. We shimmed it up to 150 ft/lbs which is fairly high.
Diff temps have never got that hot again and usually sit around 110 degrees
The main thing i dont know is what a upper limit for the oil should be??
is 120 degrees ok??
Depends on what oil you are using. I think upto 150degC at most for short periods of time? 120deg C should be fairly normal track temps.
