I'm noticing now that there are a lot of Gaps from the firewall that you need to fill. Extending right up under the dash, the whole top half of the firewall. Some holes that lead to the open, such as the windscreen wiper hole that is behind the heater where the drain is for the windscreen. All that top part of the firewall will resonate a lot of sound. It will probably make a difference to Engine noise if you can get to those panels as best you can. I found that a huge improvement was made when i did the under side of the bonnet. With just normal foam with the foil on it. That made quite a noticeable difference.
On the rear, I've always had issues with that. The reverberation just gets to you. (Side note, isn't a diff that whine's a bad thing???) Try and seal up the boot from the cabin as best you can, but don't use steel or aluminium unless you put a foam barrier between all metal surfaces, as it will rattle and vibrate like a beast (Old rally car problem). Nice work under the fuel tank. But gotta stick stuff hard all over the boot floor and in the wheel well also (if its just covered, but isn't stuck to stop the panels vibrating then it sorta defies the point of stopping the sound moving). I even went so far as to stick extra stuff under the rear seat too. But as with all old cars, Lots and Lots of steel, and as they say. Sometimes you've just gotta deal with it. (last option... Resonator on the exhaust
