It is currently Tue Jun 04, 2024 8:37 pm
Post new topic  Reply to topic  [ 135 posts ]  Go to page « 15 6 7 8 9 »
PostPosted: Tue Sep 27, 2011 10:29 pm
Thought i'd post a couple of pics of my daily aswell.... nothing over the top.. ER34 4-door, RB25Neo, Nisstune, 3in turbo back, 14psi. Makes an easy 220kw atw. Has Hks hypermax's with the damper wound right back!!! :lol: and is rolling on some ssr meshes 18x10's rear and 18x9's front. Good for the street...!
PostPosted: Tue Sep 27, 2011 10:31 pm
Looking good mate. Any reason behind the choice in the sunny switch?
PostPosted: Tue Sep 27, 2011 10:36 pm
Well it was a toss up between that and a 200b, and I stumbled across the sunny combi in the depths of the DS bowels :lol: ... Kinda like the sunny now though, purely because it has more of a period touch with the pull down levers not the twist knobs....
PostPosted: Wed Sep 28, 2011 10:02 am
That was one of the good things about the bluebird switch!
PostPosted: Wed Sep 28, 2011 8:02 pm
Yeah, i had the bluey one before. now i'm going to 180sx because it came with the Half cut. Still pull down switches and twist end for the lights!
PostPosted: Thu Sep 29, 2011 12:07 am
did anybody see the spooky faces?
too many pipes?
i can turn any hexagon into a perfect circle,pass me the multi-grips will you?
PostPosted: Tue Oct 04, 2011 10:50 pm
too many pipes?
haha this was mentioned on pg 2? definately a bit freaky...!
had a massive entry but lost it on the stupid computer :evil:
so a quick update...! Will go into more depth once I get onto a more reliable computer...!
Moved onto some more projects because my wiring is %85 finished.
Started the fuel tank with a mate, Notched it for clearance around the towers and will be marking out for spare wheel clearance which will also get notched. It will be a no bullshit design with a surge tank protruding the boot floor which will feed an 044 directly to the inlet fuel line. Should be good for around 60lt's
Started on my exhaust, It was cheaper for me to go 304 stainless the whole way through to the muffler and I will be tigging every join, pretty crazy really..anyway so I tacked the first section up. Because its my own car I have pushed the boundaries with clearance because I can alway's fix a knock! One thing I hate is road dragging exhausts. Tucked it as close as I could to the gearbox and got a nice clean shot through the gearbox crossmember, The only problem I had was the v-band is the lowest point of the exhaust so I have to make a skid plate for it so it doesnt catch. Will also be putting in a flexi join just after the v-band.
Dump
Toight ese
Also started looking for a muffler, saw these out of Japan and fell in love (only want one though) Couldnt find anything that came close here so it was off to the drawing board. Time to make my own, First thing Ive found was these handrail ends which were 100mm od which is what the muffler will be, I had to open up the I.d to 76mm on the lathe so I could fit the inlet and outlet pipe. Will update more when I get more of it together... I'm hoping to have it take away a "little" bit of the bark :lol:
PostPosted: Tue Oct 04, 2011 11:34 pm
If you put the v-band forward more (up the firewall) it would give you more clearance and wouldnt get hit.
Like your work still. :thumbsup:
PostPosted: Wed Oct 05, 2011 7:09 am
I would have if i could Nick :( , bit hard to see how tight it is tucked up next to the g/box, v-band is bout 20mm overall bigger in diameter, and accessing it there was also going to be a problem...
PostPosted: Mon Oct 24, 2011 9:06 am
Hey mate what are you doing for heaters?
-1969 1600 SR20
PostPosted: Mon Oct 24, 2011 10:47 am
Hey Cam,
Loving the build up.. engine sounds nice and lumpy..
Keep the posts coming..
Pedro
____________________________________________________________________________________________
http://ozdat.com/forum/viewtopic.php?f=33&t=14169
D4TSUN
Engine Management Sytem: Screwdriver!
PostPosted: Tue Nov 01, 2011 12:26 pm
An amazing build, Nice work.
Where do you get the Plastic brake/fuel line clamps showin in one of the pictures?
Cheers Adrian
Current car's 1970 240z #00330
1968 1600
1971 240z #00819
Previous Cars
Nissan works Bluebird SSS Z18T
240z NISMO RB20DET
260 z rally car
2+2 260
4 P510 rally cars
PostPosted: Mon Nov 07, 2011 11:29 pm
Looking good Camo!!!
SR20DET 1971 Datsun Bluebird 1800SSS Coupe - 11.58 @ 122.40 MPH 18PSI GT2871R and PLMS NIStune
Historic 1971 Datsun 1600 Wagon - L series nostalgia
Historic 1967 Datsun 1000 Wagon - A series resto
PostPosted: Mon Dec 05, 2011 10:52 pm
Cheers Adrian
I actually aquired them from a mate who had a nice connection to one of the fitters at the coke factory, They are actually used to hold hydraulic lines would you believe :lol:
Ok so its been a while, I have actually been quiet busy but have made some more progress with the exhaust.
I got over the idea of the v/band idea on the front pipe so I decided to go the old slip joint with tension springs, as per race spec. It gave me another 15mm of height from what I had before. Its nice and snug now.
Started welding up the centre section and mounted it to the g/box mount.
And onto now the rear section which got a bit tricky. Ill post more photo's up of the connector pipe through the rear x-member once finished. It is mounted with 4 cotton reel mounts diagonally opposed at each side. With a v-band on the rear side and a slip joint on the front side. It means that there is no chance of the exhaust rattling through the x-member.
Also got the rear section tucked up next to the diff, It took a couple of goe's but I finally got there... Scraped every last mm once again.
And last but not least I have made the collector for the 2 mufflers... After 6 hours I finally got somewhere with it!
PostPosted: Tue Dec 06, 2011 8:43 am
Nice looking welds there Cam.
Users browsing this forum: Google Adsense [Bot] and 5 guests
