Oil cooler install with ducting:
Some photos of the final setup:
Having a slight issue with the Z32 AFM - turbulence causing high airflow reading when dropping back to idle. This makes it too rich and wants to stall etc until the idle stabilises. With the minimum space available it is hard to maintain laminar flow through the AFM at very low flow levels. Will have to muck around a bit and see whether I can improve that.
Got it tuned last night and very pleased with the results.
The objective here was to make more power with the best possible repsonse (lowest boost threshold).
All the effort has paid off with a healthy
276 rwkw and a very fat power curve.
making
20psi boost at only 3000rpm and 25psi at 3400rpm dropping back to about 23 psi at max power
Here is a scan of the dyno curve:
Complete engine specs are now:
S13 SR20DET
Tomei 256 Poncams
GT3071R 0.78 split pulse rear housing
Twin Tial 48mm gates
Nismo 740cc injectors
Z32 AFM
Blitz EBC-II
Moroso Winged Sump
Oil Cooler
The rest is stock
I ran it on the dyno first with stock cams and then again with poncams - made about 40kw improvement.
Next stage at some point in the future will be Motec and Flex fuel so no need for AFM
but this setup will do for now.
2005 Mercedes AMG E55 350 kW
