the clunking turned out to be the dust cover off the rear of the gearbox came loose and was flopping around on the tailshaft.
I hope that the tailshaft isnt out of balance now. It seems OK with normal road driving, but who knows what it will be like at QR.
TESTING:
going at it fairly easy its running 1 min 32 sec on the big circuit.
should come quicker when its sorted
my brake booster is stuffed & the car only has good tyres on the left side
(well you only use the left side at the sprints)
I was getting in 2 or 3 hot laps and then having to let it cool down for 1/2 a lap as it was getting to 110 deg.
some videos, nothing particularly exciting except for another car blowing up an engine and me in the smoke screen
http://www.youtube.com/watch?v=2BKDKMc7kfk#
I had an engine miss which turned out to be loose plug leads.
the bugger uses a heap of fuel now
I have doubled the horsepower so i guess i now have double the heat.
plus intercooler covers part of the radiator as well.
I am in the process of pulling it apart to put in a lower opening thermostat and I am going to replace the water pump. I will use water wetter instead of coolant as well. If that doesn't reduce water temps I will have to look at other alternatives, maybe water injection ?
