Got the SU's on and running this weekend after much buggering around! Ran into some problems - including the bloody exhaust manifold has a giant flapper valve and a heater plate which is supposed to heat the bottom of the carb. There's a blanking plate over the top which you can put back on - but the bolts holding it on are quite long (they go through the carby as well) so you need shorter ones. The threads are M12x1.75 and M9x1.25 or something retarded. I've got a huge box of bolts but these two thread sizes are impossible to find - why couldn't the bastards make them M12x1.5 and M10xanything???!?!?! BASTARDS!!!!
Anyway what I ended up doing was just threading in a M12x1.5 bolt and tightening it down LOL, and used an M8x1.25 which gripped enough for the other two. This holds the blanking plate on. I'll put some pics up later of all this rubbish.
Anyway I bolted on the freshly cleaned SU's and intake, then spent about an hour messing around with float levels getting it right. I used the method of screwing the adjuster nut on the jet down by 10 turns (it's a 1mm pitch so that's 10mm down as per this:
http://www.zcarz.us/TechnicalInformatio ... ration.htm) and then trying to get the fuel level to the top of the jet. After much buggering around it was working fine.
Put in the SU damper oil I got from the carby man, filled it up to the top mark on the damper shaft. Dropped the adjuster nuts down 2 turns and cranked it. Fired up straight away, phew! But it was idling poorly and missing and farting..... we couldn't clean it up no matter what we tried. Then I randomly unplugged the float bowl overflow line off one carb and it started running perfectly - looks like the return line that I was using which goes back to the tank is a no-go, it must be blocked or something - if you air vent the overflow fittings on the float bowl it runs perfectly. So we went to tuning them - equalised the airflow with a nifty little gizmo that my mate had and then fiddled with teh mixtures until the idle didn't move at all when we lifted the pistons slightly.
Went for a drive and YES - much better. No hesitation off idle, the idle is smooth and consistent and there is a bit more grunt in the midrange. It runs fantastically and I'm pretty happy!
Now the next problem - choke cables. The 260C has an electric choke and these are manual cable-operated things. I went to the bike shop last week and got some brake cable and guide tube for a bike, then we rigged up a bracket to hold them. Didn't finish it completely but it's nice and neat - bolts to the top of the rocker cover and should work brilliantly. Just gotta find somewhere to feed it through the firewall and then mount a knob somewhere in the dash. Didn't really need any choke to start today in 13-15 degree weather though which is a good sign that everything is well!
Another problem is that the bloody 260C heater fitting on the firewall hits the rear of the 260Z filter assembly. So I'm on the lookout for a pair of small filters to fit to the SU's - I can only find K&N stuff at the moment which looks pretty expensive. Any other options out there? Going to have to figure out what to do with the rocker cover breather as well.....
