It is currently Tue May 21, 2024 4:33 pm
PostPosted: Mon Aug 17, 2015 6:11 pm
I have a question regarding clearance under the bonnet on a 1600. With the standard S14/S15 plenum and side feed injectors there is no issue. Now when you go to top feed, due to the design of the factory plenum a spacer is need to sit between the two plenum halves for clearance. This spacer is usually a part of the fuel rail/injector kit. This spacer does make the plenum sit higher. Question is... with a 1600 will this raised height cause issues under the bonnet? Will a strut brace still be fine? Here is a link to the kit with the spacer, have to scroll down a little to the S14/S15.
http://www.artperformanceparts.com/fuel ... -kits.html
