What radiator are you running? That will help decide what type of bend you want to use.
Personally I'd recommend selling your current IC, and buying a 400x300x76 with 2.5 inch outlets.
Then If the radiator is not to wide, I'd recommend going some of the tight cast 2.5 inch bends like these and get them welded on ->
http://www.ebay.com.au.au/itm/2-5-Inch- ... 3a6bef3764
When you get them welded, you may choose to first cut off the outlet part of the IC (Where you would clamp a silicone on) if you don't need them or if the radiator width allows them to be removed to reduce cutting.
I ran one of these off the throttle body to IC pipe to allow for some engine movement (hump bend)
Lastly, I would keep your IC pipe work at 2inch on the turbo side, the internet experts may be in an uproar about this, but my friend runs a 2 inch IC pipe on the turbo side to the intercooler on his 300rwkw fj20 1600 will no ill effect. Makes sense from a room perspective.
Bead rolling the ends of your IC pipes is almost a must, just take them to a fab shop and they should bead roll them for very little money, will add good strength around the areas you will be clamping.
