It is currently Thu May 23, 2024 6:57 pm
PostPosted: Mon Jul 28, 2014 4:59 pm
Can someone please confirm that adjustment here will raise or lower the ride height?
PostPosted: Mon Jul 28, 2014 5:42 pm
Yeah mate it will
1979 Datsun Stanza Coupe
1979 Datsun Stanza GX
1982 Datsun Stanza GX
1966 Nissan Cedric Custom Six
1972 Volkswagen Beetle
EziAutoParts
PostPosted: Mon Jul 28, 2014 6:35 pm
Cheers mate, much appreciated.
PostPosted: Mon Jul 28, 2014 7:42 pm
You need two C spanners to do it properly
PostPosted: Mon Jul 28, 2014 10:13 pm
Yep got 2 so tomorrow I'll see how low she can go :thumbsup:
PostPosted: Tue Jul 29, 2014 11:22 pm
Looks like you dont have much travel left till you bottom out on the bump stop but it may have slid down the shock tube and just be the angle the pic was taken at. Keep an eye on this tho...
PostPosted: Thu Jul 31, 2014 10:41 am
You should only lower the spring to the point that it is fully captive & not loose.
All adjustable platforms should not be adjusted to the point that the spring can be moved
up from the platform when front wheel are of the ground.
Any slop in the springs will reduce the handling capability of the car.
The stabiliser bar will become ineffective.
If you want to go lower then the inserts & springs should be changed.
The struts you have pictured are now not made as the trend has gone to lower ride height.
All our struts can be easily converted to much lower ride heights.
PostPosted: Thu Sep 11, 2014 3:21 pm
Hey Baz, what is your recommendation to convert the strut to lower ride height?
PostPosted: Thu Sep 11, 2014 4:19 pm
We use a shorter insert with a machined spacer which is mounted on the top of the insert.
This reduces the droop height & ensures that the shock will not bottom out.
This keeps the shock operating closer to the centre of the stroke.
The reduction in droop allows the use of a shorter spring & keeps it fully captive.
Trents struts are an example of this.
http://www.datsport.com/strut-dsk280R.html
We also have a standard insert of the same length as the adjustable insert in the 280R set up.
Any of the short struts ( including R31 )we have produced over the last 5 years can be converted
by changing the spring, insert & bump stop.
Will need our machined top spacer & if our camber tops are
fitted, a new bearing standoff is required.
PostPosted: Thu Sep 11, 2014 4:43 pm
Gotcha. I'm running Koni inserts, but your logic makes sense (keeping the shock operating closer to the centre of the stroke)
Good to hear that customers who bought your gear many moons ago (including me for that matter) can retro-fit with minimal expenditure.
Certainly no complaints from Trent either.
