It is currently Wed May 08, 2024 9:29 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page « 1 2
PostPosted: Fri Apr 25, 2014 8:31 pm
I had the same kinda issue with my carby'd one
Turns out i had a few issues including the old fuel pump was on the way out (cheap to replace) and it had a kinked rubber fuel line - might be worth a look.
Currently own...
PostPosted: Sat Apr 26, 2014 3:47 am
Blow-by fouled plugs shouldnt konk out a 6 cyl completely dead that consistantly but flooding will.
Yes you can clean plugs with a wire brush and refit. They are pretty robust.
Common causes of low/rough idle are things that affect the air+fuel+ignition mixture:
Split vacuum hoses/fittings on intake,
Blocked fuel filter/lines,
Faling fuel pump,
Blocked/rusty fuel tank (old fuel).
Faulty efi sensors (CAS, Coolant temp, Air temp, AFM, TPS, MAP),
Corroded efi plug/connector terminals (Engine temp, Air temp, AFM),
Faulty FPR,
Jammed EGR,
Sticking AFM,
Broken PCV,
Failing CAS/Ignition module,
Dirty/leaking fuel injectors,
Shorting leads/ignition coil,
Worn dizzy cap/rotor etc...
Most old datsuns burn oil thesedays. Dont sweat it, just keep topping her up...
PostPosted: Sat Apr 26, 2014 9:22 am
I would be lening towards coolant temp sensor over fueling the engine by runing it in cold mode at all times or maybe ignition module braking down.
