It is currently Wed May 22, 2024 7:32 pm
Post new topic  Reply to topic  [ 91 posts ]  Go to page 1 2 3 4 57 »
 Post subject: 1969 vh45 g130
PostPosted: Sun Mar 25, 2012 11:21 pm
as promised, some more details of my cedric build.
I bought it from my mate Ray, he was in oz for a few years before moving back to NZ. He posted a few photos of his 69 super six with rb30det turbo a few years ago (about 2008)
I got it late 2011 and this was it before i started anything. It had the big spring chop at the front and leaf flip at the rear thanks to Ray. 2.3L 3 speed column change, 6 seater
Next to my housemates late 60's merc
I was considering these wheels but they turned out to be too small to fit over the brakes
fixed the rear leafs
even got the mrs on the job
Out with the old
Crossmember strong enough for a truck!
Stripping it out.
Got this from sss engine importers
took 2 days to rip out the essentials
Chassis rails a bit narrow????
The sump sits on the crossmember
So off it came.
This handy lump of wood should be about the size of a new sump
Now its too wide.....
You can see the exhaust studs in this photo, there is only a few inches between the ports and the guard
So out it came!
A lot of stuff i wont be using, this pile kept growing
 Post subject: Re: 1969 vh45 g130
PostPosted: Sun Mar 25, 2012 11:42 pm
Engine mounts version 1. A combination of the standard v8 rubber mounts and some wood
Roughly where i want it but a bit too far forward
Original gearbox crossmember bolted straight up to the gearbox! I had to move the crossmember back about 70mm, but it was easy as the chassis rails are straight and hollow.
The rubber on the original mount was shot so i modified it to suit the v8 auto mount.
I had to narrow it by 2 cut off discs
The gearbox is massive so i had to make that fit also
Engine mounts version 2 consist of some mitsi diesel ute mounts, but the angles were not quite right
Spacer for the mount to raise the engine and get the rubber on the right angle, and push the engine back a little more
Stay tuned for engine mounts version 3!
Next job, exhaust.
There was very little room for the exhausts, It took a long time to get started but once i was on a roll iwas away. the rusty pipes were caused by me only working on the car 2 days out of every 8 when i was on shift
Easy way to cut all the pipes to length! The saw did not like it tho
Right side finished
Left side was a lot easier
PostPosted: Mon Mar 26, 2012 12:04 am
:shock: epic build mate ...love it , always nice to see something different
VG30DET 910 SSS
PostPosted: Mon Mar 26, 2012 12:05 am
I had a bit of trouble with the front suspension.
The 130 and early 230 cedrics have a smaller taper on the lower ball joint and they are no longer available. I got the last right hand side joint left in australia from nissan and there are no left side ones left.
After a lot of research and trips to various wreckers i decided to run the later model ball joint which is identical except for the taper on the stud.
from right to left,
130 left axle, 230 left axle, d21 navara right axle
The d21 axle fits the later ball joint so its straight on! But the d21 is 6 stud. A bit of research on the us minitrucking forums shows they often convert to hilux hubs to get 5 stud so i grabbed a set of them from the wreckers.
You can see the retaining nut is not all the way on. I got 6mm machines off the bearing collar on the axles and now they fit perfectly
The 4 pot gtr skyline calipers i have spare also bolt up nice
I was going to run the d21 axles reversed so the steering arms were on the rear of the axle, but this means the caliper hits the subframe before i get to full steering lock. I am now running the axles on the correct side and a mate is cnc'ing me a set of steering arms to suit
The hilux discs that came with the hubs are 257mm diameter. I changed my mind on caliper and am now running the 2 pot calipers that came with the v8. This means i need a 280mmx28m disc. The nissan x-trail front disc is a perfect fit after the centre is machined out to 83mm to fit over the rear of the hilux hub
Its a bit rugged but will work well and im happy with it
I need 16 inch wheels to clear the calipers, but after a bit of trial and error and i have decided to run 15 inch steelies from a falcon!
PostPosted: Mon Mar 26, 2012 12:19 am
The steering box that all cedrics have would have left me no chance of fitting the vh, so it went in the bin ages ago
I decided to copy the RRS style steering rack conversion, there is a bit of information out there by some americans that have done diy steering rack conversions on their old firebird things.
I got the rack from a local wrecker as the RRS setups cost at least a grand
It came from this high performance beast!
Here is the rack mounted to the original steering mounts on the car
There is a power version of the same rack but it is too wide, i think the wheels will hit it at full lock. Plus, i dont think i will be able to fit a pump and all the other crap you need.
I got a power steering unit from a holden barina or something and had a go at fitting that
I am using a combination of the original column and the barina column
Once i get the seat back in i will be able to chop the column to the correct length
The power unit is mounted to the stock pedal box that i have reinforced
The steering shaft is a bit tight against the chassis rail, but i have a hammer that knows the answer to that problem
My next mod is engine mounts version 3. I have decided how to do it with less engine movement for very little cost.
Hopefully this coming weekend i will be driving to brisbane to pick up my parts car i just bought and that will give me a bit more motorvation to do some more work on the car
PostPosted: Mon Mar 26, 2012 7:16 am
sweet mate :thumbsup:
1971 B110
1974 H230
1974 B120
PostPosted: Mon Mar 26, 2012 9:48 am
Sounds like you've got all the difficult parts covered!
I have to give it to you kiwi's, you just get on with the job and find ways to get things done.
PostPosted: Mon Mar 26, 2012 1:27 pm
Epic dedication to the cause. Keep it up!
PostPosted: Mon Mar 26, 2012 8:02 pm
Hey man well done so far, your skills leave me with no doubt we will see this cruiser/bruiser out and about very soon..
I tried to fit a 302 windsor into a 330, didnt work, not sayin it couldnt be done, just that i couldnt do it!!
PostPosted: Mon Mar 26, 2012 8:03 pm
"....and man, I pulled up next to this old car the other day at the lights. I think it was a Cedric, I don't know for sure, it was too !@#$%^& quick!! It was gone before I had a chance to have a good look....."
"Was it a turbo do you think?'
Nah....sounded different...heaps different......just like an 8"
"Like a small block?"
Na, not really, it sounded wicked but..."
:thumbsup:
PostPosted: Mon Mar 26, 2012 8:07 pm
Dave, are you seeing this! :shock:
PostPosted: Mon Mar 26, 2012 9:20 pm
thanks for the comments guys.
I wanted to fit a 6.2L commy motor and 6 speed as they are easy to tune up, just throw a cam, headers, air box, and a tune at it and your cooking. Also they are physically much smaller (narrower) than the VH motor, but they are way too expensive.
I hope to pick up the pace over the next few months and get it finished by feb next year. I have a parts car to pick up and that should increase my motivation levels sufficiently to get cracking again.
Tomorrow i think i will rip the diff out as its shagged and get a measurement. I think i have the 3.9 ratio diff and i want to run a 3.5 or 3.6. it will be a borg warner falcon or commy diff, or maybe r31, and possibly an lsd?
PostPosted: Mon Mar 26, 2012 9:43 pm
Love this car. Really good work stick with it.
Callan
fleet:
78 200B
86 ZL Fairlane ZLane
78 ZH Fairlane 500 Barn find
85 Troopy 2H Turbo
PostPosted: Tue Mar 27, 2012 1:09 am
hot damn thats cool as sh*t
exactly what id love to do for a datsun like this
damn those 8's are massive
1972 P510
1979 620
PostPosted: Tue Mar 27, 2012 6:54 am
Tricky conversion but you seem to be powering through it. Looks like the car's in good hands :)
1973 H230 Wagon, 'ILL-260'
1975 911S Targa
1978 Torana Hatch
1999 GXE10
