I have a pair of 45 side drafts webs,am I ok with the mechanicle....engine builder says not,but im not sure,im happy either way.
opinions?
I wouldn't see y not, like i had mentioned the only advantage i could see would be on startup.
The only thing i have done is I went to sprints today to look at changing the 1/4" fuel line to 8mm from the filter to the carbs. Depending on ur pump u might have to change the inlet and outlet on the pump itself. For some reason my filter has an inlet of 8mm and outlet of 1/4" then 1/4" to the pump then out to the webers. Im just going to run an inline filter and run 8mm straight thru to the webers.
Honestly i doubt it will make much, if any, difference but just look a bit cleaner than the braided aero flow sh*t thats there at the moment.
