It is currently Sun Apr 28, 2024 4:14 pm
Post new topic  Reply to topic  [ 334 posts ]  Go to page « 117 18 19 20 2123 »
PostPosted: Mon Nov 22, 2010 5:45 pm
how much?
PostPosted: Wed Feb 23, 2011 10:13 am
So i did some work on the car, patched the rust in the bonnet, rego today.
Base price will now be $2500 not $2000 due to it having a stack of rego on it now!
PostPosted: Thu Aug 18, 2011 11:24 am
So after not doing anything on the car for a while (except driving it!) i've started to tackle some of the rust coming out in it.
The first part I'm going after is the rust that is coming through from the airbox/cabin intakey sort of area behind the bonnet, through the seam, into the engine bay. Sort of hard to describe but there are some pics below.
So i'm going to clean all the crap out of the seam area behind the bonnet (leaves, dirt etc), wire brush the rust in the engine bay back to bare metal and then go from there. Originally I was going to drill out some of the spot welds in the seam, split the seam apart and clean it out more, however that'd be quite difficult to do and looking around i wouldn't mind trying out rust bullet on it (despite it's cost) just to see how it goes. If it DOES work the way they say it does (has anyone tried it?) i should be able to coat the front and back sides of the seam, it should more or less neutralise the existing rust, then coat it again and it should seal it all in without having to split the seam apart to clean it. I'd probably coat the entire inside of the airboxey area just to be safe.
Any comments on that plan? I'm not sure the product will work as they say it will but it seems like a good place to test it at least!
And the pics:
The cover taken off between the windscreen and bonnet.
Inside the area.
And where the rust is coming through into the bay.
PostPosted: Thu Aug 18, 2011 12:29 pm
That's a very common place for 200Bs to rust, although going by those photos your is worse than any of mine have ever been! Wire brush it and see, mine only ever had surface rust there.
PostPosted: Thu Aug 18, 2011 12:50 pm
Yeah I'll be hitting it with the wire brush soon, got the die grinder and a selection of brushes sitting on the car right now actually.
On a different note does anyone have issues with their rocker cover leaking? Mine leaks past the (new!) cork gasket like nobody's business!! :(
PostPosted: Thu Aug 18, 2011 6:45 pm
i certainly do! i have blown about 4 gaskets in the last 2 years. the one i put on about 5 months ago was thicker and better quality seems to be doing a better job so far.
Callan
fleet:
78 200B
86 ZL Fairlane ZLane
78 ZH Fairlane 500 Barn find
85 Troopy 2H Turbo
PostPosted: Thu Aug 18, 2011 10:47 pm
have you got clogged breather pipes or used tiny amount of red rtv when installing?
1600s arent the only datsun
PostPosted: Fri Aug 19, 2011 6:39 pm
no red RTV, breathers should be all sweet, pipes are all new about 18 months ago.
PostPosted: Sat Aug 20, 2011 6:00 pm
well i claened my alloy head with wax grease remover and rocker then fitted a gasket with a very thin film of rtv both sides it never leaked try that maybe and tighten from middle outwards
PostPosted: Sat Sep 03, 2011 3:36 pm
Got a new rocker cover gasket, just got to put it on now...
Also did some other stuff on the Datsun today, what I'm currently doing is cleaning out the front end of the car, removing any rust and the plan is to seal and spray it all.
So i previously took the vent off around the front of the windscreen to gain access to the plenum and remove all the leaves/dirt/crap that's accumulated in there and whatnot. Today I blasted out that area with the high pressure water gun, and removed the guards to clear out the drains on either side (the plenum drains more or less into the back of the guards).
Managed to clear alot of crap out of in there, so it'll be onto the rust next, luckily there isn't much there, if left it'd become a problem but for now it's just starting from the surface for the most part. I noticed that Datsun never seam sealed any of the car when it was new, so I'll probably seam seal every seal i can get to and wire brush while i'm at it. Oh yeah and I need to re spot weld one of the headlight brackets, they tend to pop apart every now and again. Pics below :).
Bumper off.
Headlight holders.
Guards off.
Inside the plenum
PostPosted: Mon Sep 05, 2011 8:17 am
Later 200Bs were seam-sealed, I've never had am early one that was though. Once you've cleaned your plenum out wave sure you clean out behind the guards too, the accumulate heaps of crap there.
PostPosted: Mon Sep 05, 2011 11:07 am
Did that already, cleaned out all the drainage out of the plenum and etc.
One guard has a small bit of rust, i'll fix that, strip and repaint all the area behind the guards, and seam seal whatever i feel needs it before i put it back together. :)
PostPosted: Tue Sep 06, 2011 3:22 pm
i had a lot fun doing that to. Heaps of crap in mine the previous owner had it under a tree. Have you decided not to sell the car? all this work i doubt i could sell it anymore.
Callan
fleet:
78 200B
85 Troopy 2H Turbo
PostPosted: Wed Sep 07, 2011 10:56 am
nah i decided not to sell it a while ago, i never really wanted to sell it, it was more a practicality thing, but i talked myself around and i'm keeping it now :).
PostPosted: Thu Sep 08, 2011 4:21 pm
thats good to hear your golf front lip inspired me. Also the wheels. i think all car owners go through phases of almost selling i just about sold my 200b a few months back and 78 bought a ford LTD just a small change of car really.
Callan
fleet:
78 200B
85 Troopy 2H Turbo
Users browsing this forum: No registered users and 10 guests
