Tims Datsun 510 build http://ozdat.com.au/forum/viewtopic.php?t=32640 |
Page 8 of 8 |
Author: | SR20Datsun [ Tue Jun 26, 2018 6:33 pm ] |
Post subject: | Re: Tims Datsun 510 build |
Any updates on this Tim? |
Author: | datsonial [ Wed Jul 04, 2018 11:35 am ] |
Thanks for still showing interest guys. Seems photobucket is fixed, yay! Over the last year I've still kept working on the Datto, weekends, weeknights. Mainly working on the body, repairing rust in the doors and front guards. As of 12:22 last night, the car is officially painted. Will uploads some pics soon |
Author: | Hatchman [ Thu Jul 05, 2018 12:08 pm ] |
Awesome! |
Author: | SR20Datsun [ Mon Jul 16, 2018 9:51 am ] |
What kind of paint is it? If it's 2K then thick coats are the only way. Also if it's 2K, then you will have to sand back the whole area you need to paint and paint that whole section (so the whole door, or whole boot lid, or whole rear quarter). |
Author: | datsonial [ Mon Jul 16, 2018 10:34 pm ] |
Yeah it's 2k, it's lookin' like I'll give the whole car another wet coat. Any idea if it's OK to paint straight over the super fine (1200 or higher) Or should I bring it back to 400.. |
Author: | SR20Datsun [ Tue Jul 17, 2018 10:05 am ] |
Tim, I'd probably go straight to 600 grit. Scuff it up a little and wet thick coat the whole lot. 400 may leave marks visible through the top coat. 1200 is probably to fine and it won't key as well. Any areas that are bare metal, i'd prime first. My painter recommended to leave areas that are primed at least 2 weeks for them to fully outgass if the weather is cold. Melbourne is bloody cold at the moment... The good thing about this is you are going to see any imperfections now that you can work on before the 'final perfect' coat. So try and concentrate on areas that aren't quite there before putting the final coat on and you will be laughing. If the coats are thick enough for the final, then even if you orange peel, you will have enough material to polish it out. |
Author: | datsonial [ Tue Jul 17, 2018 6:52 pm ] |
Thank for the advice, I better get sanding (again) I'll let you'll know how it goes |
Author: | Ant-Dat [ Wed Jul 18, 2018 5:36 am ] |
Sure you not done this before? Awesome work mate, Keep it up. |
Author: | 68DAT [ Fri Dec 13, 2019 6:29 pm ] |
How'd this end up? Good build mate. |
Author: | datsonial [ Tue Dec 24, 2019 8:12 am ] | ||
Post subject: | Re: Tims Datsun 510 build | ||
Hi guys, Long time no update, mainly because there’s not much to update My garage paint job turned out rough, but for now it’s acceptable. Looks good in pics but it’s far from decent which is a bummer. But, its a datto so it will do for now! Plan is to have it professionally done one day. Have been piecing bits together slowly. The car runs, drives and stops I had water pissing out my bellhousing due to a rusted out welsh plug which is so annoying as I’ve disconnected everything thing, box out ect So now I have to find motivation to put it back together lol I’ve got a SSS 68 dash which I’m restoring, it’s looking ace
Page 8 of 8 | All times are UTC+11:00 |
