Not much can be done apart from slow down the rusting process. Clean the affected areas and paint with a rust converter. Remove all the sealer between the frame and skin and clean also. Paint with whatever method in instructions for the rust coverter. The sealer is what has cuased the rust in those areas, it, I have been lead to believe had an acid in it. Removing the sealer will cause the bonnet to flex. This can be fixed using body sealer, NOT urethane. Urethane will pull on the skin, leaving what looks like dents.
